Sr swap power steering help!!
mugenrsx
I dont know what this plug is for i hooked the power steering lines to the one on the far left but im wondering what this hole is for?? do i just plug it up with a bolt or what?? help me!!
Hijacker
Car: '92 240sx Convertible
'94 F-150
You have a HICAS pump.
I would personally rather source a regular pump, but you can pull the fins out of the backside of the pump and plug up the holes. I recommend pulling the fins just to help on engine load.
mugenrsx
so i can plug it up i dont know anything about a hicas pump but i just plug up the hole and i dont know what fins you talking about??
mugenrsx
and when you talk about regular pump do you meand a dohc ka one?? something?
jeking1
Car: 95 240SX SE, sr20det, time attack advan avs, megan coilovers, mmm mmmm good
no, there is an sr pump with only one port, it's for the non-hicas models, which most are. I would strongly suggest against plugging it, you should just get yourself a regular one. If needed I can ship you one, I can get you the full price tommorow if you are still interested.
mugenrsx
yeah that would be great and another thing you seem to know alot do i need the dohc ka a/c compressor to make it fit for the sr20 cause the sr20 wont work so im guessing i need one of those!
jeking1
you have a few options, you can try to bolt the ka compressor on, but only a couple bolts will fit and that is not too safe considering it will have the load of a belt on it. The other option is getting a bracket for the compressor to fit on the sr bracket, if you search on here you can find a few from some different makers. The last option is getting the ends on your ac lines cut and having a shop attach the sr ends. Then it will fit on your sr compressor and all will be well. choice is yours.
just to make it easy on you, go to this for your a/c bracket if you go that route.
zerothread?id=298648
BLACKDIAMOND
Car: 240SX
BRO, I HAVE A REGULAR PS PUMP AND I DESPERATELY NEED A HICAS PUMP.... LETS TRADE!!!!!!! PLEASE I NEED THAT PUMP. E MAIL ME @ [email protected]
