180fan »
https://forums.nicoclub.com/180fan-u3602.html
Tue Oct 12, 2004 3:09 pm
98 180sx ecu's do not have the same pinouts as the 91-96 ecus. If you've used the 98 harness for the 98 ecu and still no luck after the redtop ecu/harness combo, it's probably not it. If you're not getting combustion at 1 and 4, have you checked the spark plugs for sparking? If it's 1 and 4, it could be your ignitor, since the chance of 2 coil packs going out at the same time is pretty slim or it could be your cas. Try a different cas as the last resort since it's a bit of a chore to line everything up TDC.
Have you checked the injectors? They're supposed to be around 12 or 14 ohms. Check them for clicking also when your motor's running and pull the injector plug while the motor's running to double check to see if the injector's functioning, that is if you're getting spark.
EDIT: just saw you're getting spark on all 4. Then it's gotta be fuel, unless you've got something severe like blown up pistons or shot valves.
