SR swap hits brick wall
slydways6
Car: 95 s14
Alright so I thought my first sr swap was going to finally be complete tonight but I was wrong. It will not start at all. Only one click after the key is turned. I just swapped in brand new upper and lower harnesses tonight. I have swapped out three starters. Checked all the grounds. Checked all the the plugs and outlets. Tore the multi junction out and put back together. Even tried tapping the starter with a hammer. I have hit a brick wall. I dont know what else to check. I started checking fuses tonight but I dont think thats it. Do I have to do something special to make a sohc main harness work? I dont know whats holding her back from startin. Any and all help would be greatly appreciated
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
The starter just clicks our does nothing? Also was your car an auto before hand?
Chris859
if it just clicks once - I would say bad or dead battery, or possibly as simple as a bad connection between the battery and cables.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Have you made any progress since then?
S14Magician
Car: 1995 Nissan 240sx
I had this problem when I put a new starter on my car. Turned out that the solenoid post on my starter was so long it was grounding out mu starter on my engine mount. Grinded it down a bit so it wasn't grounding and she fired right up
slydways6
Car: 95 s14
Sry guys first time ive been back on since i posted this. Figured out the problem the next day. Turned out to be the ignition relay that i completely looked over and had sitting in my garage, smh. Thanks for the help
