SR swap help...tired of searching
Tartan
Car: 89 240sx
Hey trying to start my sr20det and it cranks and cranks and wont catch. I have a spark, I have oil pressure. I pulled the plug and found no fuel on the plug. The fuel pump comes one and I pulled the fuel line off the fuel filter and it had fuel in it. Im so stumped right now and could use some help. Thanks.
Tartan
Car: 89 240sx
Anyone? Help?
Tartan
Car: 89 240sx
Well I pulled the hose going to to my fuel pressure regulator and found that it was dry. Is that normal? Isnt it supposed to be a return line?
ride4lame
are your sure thatou have the fuel lines hooked up corectly?The one coming from the filter, goes to a line between around the 1st and 2nd cyclinder, Then you should have a line that goes from the fuel pressure regulator to a return line...
Anyway, it might be smart to post this in the SR forum, but good luck
Tartan
Car: 89 240sx
Alright I installed my walbro fuel pump and now it cranks and catches but wont stay on. The dash doesnt work unless I give it some gas, then it comes on and the windshield wipers come on and they arent even switched on. I can manipulate the throttle to keep the car on but it seems to want to die. Anyone know whats going on?
