johngriff »
https://forums.nicoclub.com/johngriff-u30588.html
Sat Sep 22, 2007 4:02 pm
The S series DOES NOT use a vacuum assisted steering system. Commonly cheap SR swaps into 89-90 chassis, the installer does not connect the "high pressure power steering line" because a different line is needed than is provided with the chassis or the motor.
Ask your installer if he connected the:*High Pressure line*Power steering belt*low pressure and fluid tank
This is MORE than likely your problem.
The ONLY other possibility is that some poorly fabricated or custom down pipe that is obstructing the steering rack input shaft.
The latter is least likely.
