KYZAAC »
https://forums.nicoclub.com/kyzaac-u147135.html
Sun Jun 19, 2011 10:59 am
i checked the relay panel with a test light, everything gets power except the EGI Pump relay and the fuel pump fuse.
i had a neighbor check out the wiring, he said the same thing as you, but we checked it out and couldn't find the problem. we hooked the battery back up to the stock setup to eliminate the relocation, all grounds are going to bare metal, we disconnected the alternator, and it was still blowing the fuses. we pulled the harness apart to check any frayed or damaged wires, everything checked out.
is it possible a bad starter could cause this?
it will only blow the fuse when the started is turned over, it will crank for 5 - 10 secs then blow. and the starter cranks pretty slow, even on a new battery.
he suggested to take the starter off and hook it up direct with an inline fuse to see if it blows.
