white90esex »
https://forums.nicoclub.com/white90esex-u35623.html
Fri Feb 17, 2006 9:45 am
Ok, I decided that I want do get an SR. I know I will need motor mounts transmission mounts, driveshaft, brake/ clutck pedals, not sure what else.
The motor im buying comes with everything I think. ECU, wiring harnes, water pump, starter, 5 speed, everything else too I think.
Anyone think that I will need to buy anything else?
I have a friend with a CRX and he did the ZC swap. He said that whenever you do an jdm swap you should allways change the seels.
On the other hand we just swapped a Turbo 7M in my friends mark 3.... No seels changed on that and its fine.
I need your guys imput on what I should do when I get the motor. I dont want to put it all in and discover that I should of done other things too.
Im also going to paint my engine compartment black so that once I paint the outside of my car black the engine bay wont look stupid in white.
