sr stumbly idle
okinawa drift
Car: 89 240sx SOHCoupe
this has been happening from the start but its kind of getting worse... the fact that the motor wants to stall out after revving now.. used to only do that when driving
its very shaky, and it wants to stall out after i rev it, and as you can see my bov ain't doin s***..
http://www.youtube.com/watch?v=qmqkPeYjk58
240_SeX
Car: 1992 240SX SE
Looks like you've put that intake manifold on recently, did you check the condition of the IACV?
okinawa drift
yeah i actually took it out and cleaned it, and the intake manifold came with the sr...
hmmmm anyone got any ideas?
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
time to run some leak down and compression test on your motor, and do a leak test on your inter cooler and pipes.
okinawa drift
i did a comp test and it got 160 on all 4 cylinders, hmm the bov doesn't seem to be doing its job
240life
okinawa drift wrote:i did a comp test and it got 160 on all 4 cylinders, hmm the bov doesn't seem to be doing its job
Yeah That is where i thought the leak might be coming from. I would bring that pipe to a local radiator shop and have them leak test the flange and weld it if it is leaking, my buddy had to do that to his
240_SeX
Car: 1992 240SX SE
you can just build a boot leak tester and pressurize your entire intake/intercooler@piping with compressed air and listen for a leak.
240_SeX
Car: 1992 240SX SE
240life
yeah anyone can build a leak tester, but most people dont have the access to an aluminum welder to make the pin hole repairs or weld the flange solid.
240_SeX
Car: 1992 240SX SE
That's very true, be that also may not be the problem. I'd rather spend the $5-10 to build the leak tester than pay a shop to test it. Plus its a nice thing to have. If there is no leak and its a different problem there's no point in removing all you piping and having it tested.
240life
Oh i agree trust me but those shops are used to looking for and finding pinhole leaks, obviously my way isn't the only way to go about it, it just the peace of mind
240_SeX
Car: 1992 240SX SE
I doubt its a pinhole causing that much of a running problem, however if it were id agree with the rad shop, small leaks can be very difficult to locate on your own.
i'm pretty confident that we are dealing with something bigger here tho.
okinawa drift
ok so, i found out what the problem was, i wired up my e-fans waaayy wrong, i was in a hurry.. anyways i shoved the power wire to the efans under the engine controll fuse and the fuse blew, then all hell broke out...
anyways, i replaced that fuse, re-routed my vacc lines.. and it seems to be ok
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/GVujoAdHCl0&hl ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/GVujoAdHCl0&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
its still shakey at idle though... and it surges like crazy still
