SR Stock side mount IC Vac. Hose???
Gmans13
Where does the vacume hose go to that comes off the ic? It splits in to a T but then where??? If some one could help me out that would be cool.
S13240
It goes to the bigger vacuum line located above the throttle body.
Gmans13
I thought the big one that came off the throttle body was one of the ones that goes to the canister? Also It T's to where does the other one go to?
themadscientist
The "purge" line on the canister that he mentioned is the right one, Tee into that.
Gmans13
One more thing...there is a little nipple that comes off the end of the ic piping that is connected to the throttle body what do I connect to that?
Gmans13
found a pic of the hoseless nipple with a hose
themadscientist
Does it look original or like someone added it?
Gmans13
It is original it is the thing that the hose is connection to in the pic above.
S13240
That hose is from the wastegate. Wastegate gets it's signal from the ic piping...that's the stock location for the stock smic.
BuudWeizErr
Doesn't the wastegate get it's signal from the hotpipe, before the intercooler? I don't know if it matters, but I know my hotpipe has the nipple for the wastegate actuator on it.... before the intercooler.
Gmans13
are you using the stock ic and wastegate?
themadscientist
there should be a hose on the compressor housing of the turbo going to the actuator for boost control. It might be a silly question but does your blow off valve work now?
S13240
Buud: You must have an fmic that's why you have a nipple on your hot pipe for your wastegate line to hook up to.
Stock smic has the nipple on the cold side as you can see in that picture posted. I btw am using the stock smic.
BuudWeizErr
i'm using the stock wastegate, but a GReddy V-Spl intercooler.
you can see the hose coming out from under my hotpipe and going to my wastegate.
S13240
Pic doesn't work Buud! : )
Don't worry Buud...I also trust Wayne as I bought my ecu from him. Very nice guy and he was the one who told me to plug my wastegate line to that little nipple on the cold pipe side for the stock smic piping.
Gmans13
Correct me if I'm wrong but the stock wastegate is what I posted in the first pic above right?
BuudWeizErr
No, you posted a picture of the stock reciculating valve. The wastegate connects to the exhaust turbine.
FTRS14.5
Try this place:http://www.eurostreetgraphics.com/srswap.htmMight have your answers
pampadori
Car: 91 Nissan 240SX coupe
this thread is all sorts of confusion. the stock t25 on sr doesn't have a fitting on the compressor housing like mad scientist said, the bov fitting tee's with the bigger of the two carbon can hoses, the fitting nect to the radiator shroud does go to the boost sensor of the wastgate. shaun
