dtowndrifter »
https://forums.nicoclub.com/dtowndrifter-u33634.html
Mon Feb 23, 2009 6:15 pm
did another ground no fixin the prob..
ok this car is still sputtering/misfiring...right when i'm giving it light throttle like at 2 grand/rpm maybe 2500 EVEN WHILE THERE IS NO LOAD......absolute headache..
Changed out the MAF, TPS, O2 sensor, Coilpacks, Spark plugs, Ignitor, Cas, Knock sensor, Pcv valve, great fuel press..no vac leaks. no boost leaks. check for leaky bov..checked boost controller...disconnected boost conroller and bov..checked to see of the coil pack harness was grounded and is...no grounding out on the harness either....tps within voltage spec..has resistance so does knock sensor..
Only things that Havent been checked are injectors or ecu..maybe and possibly the wire harness..last but not least...hell i dont kno..
