180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Aug 16, 2004 12:21 pm
you don't have vacuum? uh yeah, that right there sends red flags galore on your idle issue. so how's your vacuum setup? do you have caps on all vac lines that aren't being used? replace your vac lines with new hoses. the vac setup i've got is this. there are 3 vac ports on the throttle, two on top one at the bottom. the top, i've got one going to the bov, and the other (farthest away from the driver) going to the fuel pressure regulator. the bottom one is for the carbon canister, and i've got that capped. at the back of the intake manifold, there's the vac port for the brake booster. Do you have that hooked up? On the cold pipe, there's another vac line for the wastegate actuator. That should be it, all other vac lines are unnecessary. If you want to take it a step further, if you look at the top of your intake manifold, you'll see a pipe that runs to the pcv in the valve cover. I made that pipe disappear and ran a hose from runner 1 to 4 and put a breather on the pcv instead.
