SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Wed Feb 25, 2004 10:57 am
If your getting spark on all four then your CAS timing is just way off. Lets say the pistons should be getting ignition in 1-2-3-4 order, you would obviously want your timing to be at 1-2-3-4. But it is possible, even if you follow how the manual tells you to set timing, that the firing may be 180 degrees off like 3-4-1-2, which would obviously seem like its set right, but in fact be doing nothing.
Other things that suck for multiple starts: As stated before, you can flood the engine thus it will not start again until its dry enough. This sucks if it doesnt start within the first few tries because it means you have to wait or remove the plugs and dry them. The other problem is battery voltage, simply put if you drain the battery anything in the low 12 volt area its not electrically strong enough to start the car anymore with the charge in the system at basically nothing (since the alternater hasnt had a chance to charge anything) thus you may need to have a car jump starting while you try to start.
Have one person cranking, while the other turns the CAS slowly. The way the CAS works is that it has a metal disc that turns. The disc has 360 holes etched into the metal. A laser shoots through each hole and when it gets a certain number of holes it reports to the ECU to fire off a plug. Since the car is in start mode when you are starting, fuel is shot into all four cylinders at once, as opposed to one cylinder at a time during regular driving. This is the reason why if you arent getting it to ignite fast you flood the engine, since its recieving four times as much fuel as regular driving.
