SR starter squeels during startup.
driftneil
Car: A pile of cars.
Hello again Nico, I had just purchased a 95 s14 with a blacktop SR. The only major problem Im having is the starter. It makes a high pitch whine when I start the car, kind of the same noise you get when you try to start the car while its running.....So is this a starter problem, or could this be a flywheel problem? Anyone heard this before, and know whats the problem? If I get no replies I guess I will have to swap starters...Thanks for reading.
driftneil
Anyone?
ghost_22_47
Car: 1993 Nissan 240sx Covertible with RB26dett
2004 Audi A4 1.8T Quattro
Yeah, first check your S connector, which is the little wire usually between the main terminal connectors on the Solinoid and make sure it's not loose.
If it is still starting then it could be the teeth on either the starter or the flywheel are rolled or stripped, so the starter teeth that are supposed to be turning the flywheel but they are just spinning. But you can remove the starter and turn the engine by hand and check all the teeth rather than pulling the trans and if all the teeth look ok then just replace the starter and solinoid and see if that works.
driftneil
It does start, sometimes takes a couple times. So Thats the next plan of attack....Guess I will pull the starter tom. Thanks
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
The starters on the SR are notorious for this issue. When you replace it find a "mitsubishi" brand, seems to be less problems with those compared to the hitachi.
driftneil
Thanks bro....Know anything about the isis starter?
