Clawhammer »
https://forums.nicoclub.com/clawhammer-u53050.html
Tue Apr 15, 2008 8:02 am
Possibly, the only way we'll find out is trial and error. I got lucky that I didn't get a mitsubishi starter, so I'm not sure. If you buy a mitsu and it doesn't work, take it back. It's only 2 bolts to find out if it works, and isn't rocket science to put it back together so don't be intimidated. If you take the heads off and they look the same, then you're good to go.
I don't know if the mitsu's are different, but my two starters had a big ring with gear teeth on the inside and then 3 little gears that sat in the middle of that (in the teeth of the big outer gear) and the head had 3 nubs that went into each of those 3 gears.
