Sr Staring problem?????
burgy240
Car: 2000 Q45 Ann. Edition Blk on Blk
I just took my car out of storage and everything seems to be good except that I have to disconnect the battery and reconnect it to start it each time. Once the car shuts off I can't get it to turn over again. Anybody have any ideas??? thanks, joe
Silvia007
Car: 93 Nissan 240SX SE Fastback
Does it click when you turn the key? Try jumping? Funny how it would do that.
deCksy
check the connection on the terminals... if its all growdy, then clean it up and try again
tony/ka24de
you probably have a bad ground, check the ground that goes from the battey to the frame and also from the frame to the engine. To see if this is your problem without changing the ground wire. Just get a big ground wire and touch it on the battey and the other end on the engine block. Then get someone to start the car.
