sr stalling pleas help!
nismo200sx16
Car: 85 200sx (s12)
ok my sr keeps stalling when I come to a stop. my setup is pretty simple. red top with a fmic hks ssqv. the bov is located in the throttle body side(cold pipe). I originally just had it venting to the atmosphere I though that was why it was stalling. but I just hooked it up to recirculate between the maf and the turbo. and it still stalls when I come to a stop. I can rev the car up from a stop and it blows off and doesn't even stumble. it only happens when I try so slow down and stop. when I re start it I can rev and have it blow off and it doesn't stall. I also installed a hks eids (electronic idle stabilizer) still stalls. car runs great other than this stalling thing pleas help.
S13240
I say it's the SSQV leaking
nismo200sx16
Car: 85 200sx (s12)
how would it be leaking? I tested it by taking off the recirk hose and actually sucked on the bov and it didnt leak. at idle it shouldn't even be sucking on it very hard. I will take it apart and check it again. but I don't think that's it.
deCksy
nismo200sx16 wrote:how would it be leaking? I tested it by taking off the recirk hose and actually sucked on the bov and it didnt leak. at idle it shouldn't even be sucking on it very hard. I will take it apart and check it again. but I don't think that's it.
hows your timing?
nismo200sx16
Car: 85 200sx (s12)
15 deg btdc
DRIFTINIZ
deCksy wrote:
hows your timing?
yea, could be your timing.....mine is also at 15 degrees (factory setup).......never get a stalling issue so far (knock on wood)......make sure all your vacuum lines are on tight.....when i first got my car it would stall b/c my intercooler piping kept coming undone.......
j87w
Car: 90 240sx
I got the same problem man.
