adstudio3d »
https://forums.nicoclub.com/adstudio3d-u49665.html
Mon Apr 23, 2007 3:47 am
I've searched but could use some help.
My SR has been running like crap. There are 2 problems that I know about.
My setup:Blacktop SR, FMIC, Stock T25, Turbo XS BOV (Recirculated), walbro fuel pump, koyo rad, ect...
1. When slowing down, then drop into neutral to stop the car stalls sometimes.I've searched, I just wanted to make sure I checked everything that could cause this.- Tighten the bolt on the BOV- Check FMIC piping, clamps, and couplers- Check the sensor under the intake manifold and on the throttle- PCV valve?- Fuel filterAm I missing anything?
2. The new problem I just noticed. The car bogs and is running rich. If I accelerate slow there doesnt seem to be a problem, but if I punch it or hit boost, the motor revs like normal and sounds normal but theres no power. I'm thinking that the piping after the bov has a leak since the bov goes off like normal after letting off the throttle.
There is also oil getting spit out of the BOV (btw it is recirculated), and there is a little drip of oil coming out of the coupler on the turbo outlet.
Any ideas? Possibilities? I had a couple friends that own a shop do the swap for me since I have no garage, but I've just been having problems with it since... I just want to get my car running the way it should.
Any help would be appreciated.
