I'd worry more about people being pissed for spewing off wrong answers, but that's just me.pauliedrft wrote:you must use the usdm speed censor for your cluster to read in miles per hour , not kilometers per hour .. but next time spend the time searching . people will get Pi$$ed . i spend about 2 hours a day just researching .....
I have half a mind to delete your post because it is absolutely, completely wrong.pauliedrft wrote:you must use the usdm speed censor for your cluster to read in miles per hour , not kilometers per hour .. but next time spend the time searching . people will get Pi$$ed . i spend about 2 hours a day just researching .....
Thank you. This is my first sr20 swap. Hell first swap in a 240. I've done a couple dozen swaps in my time as a backyard mechanic. So I've spent months reading up on certain things I have questions about. When it came to the speed sensor I was getting conflicting stories.Hijacker wrote:
We've proven that the US and JDM sensor pull the same part number in FAST. If you really spent some time searching, you would have seen this in threads of the past. Also, the only difference between a JDM gauge and a US gauge is that the US gauge has MPH as well as KPH, and guess what?? The KPH on both gauges match! You do the math on that one.
Sensors do have to be calibrated to a gauge to work perfectly, that's why there is a fine adjustment screw on each speedometer. Also, a number of things throw a sensor off. Tire size for one. Not every tire is made at the exact same outer diameter, plus this number changes as a tire wears down. This is also why most localities don't ticket at 5 mph over the limit due to a law school reject could argue the point.
I have personally used JDM speed sensors and done a 60 MPH test on the highway and it works fine. The only reason I tend to use a US sensor is just to keep the sensor mated to its gauge, but if I do a swap on an auto chassis, I have no hesitation to use the JDM 5 speed sensor.
I changed my post and have been researching the s-14 sr swap into the s-13. (i.E watching the wiring video i bought .) mostly the s-14 into the s-13 part ..Hijacker wrote:
