240life »
https://forums.nicoclub.com/240life-u76914.html
Fri Dec 26, 2008 2:26 pm
first things first, this engine has about 600 miles on it after a rebuild done by me. The issue came out of no-where shoppinng for christmas presents.My previous symptoms were as follows....after warming up I would have a hunting idle between 400 and 900 rpm, sometimes it was perfect.This engine ran perfectly while driving, no hesitation boosted fine and had more then enough power.The engine started sounding like this out of no where, I shut it off to go into the store (was running fine)...When I started it back up it sounded like a subie.Things I changed that day.... New BKR7E plugs gapped to 28 ran great untill the issue started.Things tested....that day I found a coil pack that looked to be running hot so I bought a new one, installed it, but the problem still persists, I cleaned my MAF.....I also tested my fuel injectors resistance (10.3-10.9 ohms)....if anyone else can think of anything else I can check I would appreciate it...I am checking the compression tomorrow if it isn't to cold (my car had 3ft of snow on it for a couple days) i am expecting 150 psi cold as it was trhe week before..
