Neil »
https://forums.nicoclub.com/neil-u15642.html
Sun Nov 06, 2005 8:11 am
I got this whole thing when I bought a Coilpack. I know what the coil pack is, but what are the other thingies for? I've read around where people say if you get a motorset it usually doesn't come with wastegate actuator things so it opens gradually between 0 and 7psi, instead of closed but opens sharply at 7psi. Are these for that functionality?
The black cap on the green sensor ( the >right> one) can turn but it doesn't have a stop, nor does it even indicate +/- per direction. I wonder what it is used to adjust or even if youre supposed to turn it? Of the 2 lines on it one of them is capped off. if i remove the cap and blow air through it it sounds like its exiting from under that turnable black cap on top. The other one I cannot blow or pull air through at all, so I assume that one is a vacuum sensor, or actuator of some kind. I assume the line that's capped got a cap from the previous owner for some homemade mod, because why would they make the blowthrough and not use it? another reason why i think its a cheap homemade mod is cuz the cap is so badly dry rotted already that its probly cheap *** material, which im (merely) assuming Nissan wouldnt use.
The other one on the Left also has two lines which tells me its a differential pressure sensor to keep some valve's operation in check. but which? Is this the one for the wastegate?
