Badfish »
https://forums.nicoclub.com/badfish-u12045.html
Sun Dec 11, 2005 6:38 pm
Check the oil pan for dents as even the smallest dent can screw with the oil pickup. Replace with a new stock one or if you want, get a high capacity oil pan with baffles to keep oil in the center of the pan under hard cornering.
Its good to replace the water pump and upgrade the cooling system(bigger radiator, electric fan, new thermostat etc.) as overheating is a weakpoint of the sr20det as well.
The 4 hole turbo gasket likes to blow out and isnt any fun to change while its inside the engine bay. Also,If your going to be pushing your car and reving high I would put some in rocker arm stoppers as well.
Of course, change all fluids,oil filter, fuel filter, sparkplugs, and get some gauges to monitor your readings.
