SR running very HOT = overheating.
kylaris
My set up is as follows:
S13 SR20DET btnismo thermostatKoyo RadiatorPermacool 14' + thermostat relay
My car is running very hot. I have to run with heater on full blast to just to keep the temp @ 3/4 of the stock gauge.What can be wrong with it?
Any one has any clue?
thanks,
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Stock gauge is useless, try getting an aftermarket one to see what your real temps are.
Cyberkreig
Car: 1993 Nissan 240SX SR
Jspec, you should know this.
Kylaris - The S13 SR temp sensor doesnt read on the same scale as your s14 gague cluster. Swap to S14 sensor.
Onizuka
Me? Reliable and accurate information? C'mon :D
kylaris
So it is just gauge fault, nothing major? The radiator is really hot though. I can't keep my finger on it for more than 1 sec.
I guess, I will just get the aftermarket and see.Btw what is normal sr20det temp?
thanks,
Cyberkreig
I cant promise that the gauge is the only problem, and obviously running hte car in that state of overheat (if it is really overheating ) will grenade your motor.
What i can tell you is that the S13 sensor shows super high temps on the S14 gauge. And thats where I think you should start. IF you are silly enough to drive your car without KNOWING it isnt overheating the results are your fault!!
Onizuka
Its normal for the radiator to be hot, I'm pretty sure the water should be at 80-110 F
Cyberkreig
80-110? The temp should read close to whatever your thermostat is. Think about it. If you have a 180* thermo.. The cooling process wont start till 180.
Onizuka
celcius i ment
180fan
Car: 89 fastback
koyo 2 core gets pretty damn hot. I mistakenly put my hand on the "KOYO" lettering when I was checking over some stuff on the motor and wasn't paying attention to the pain in my right hand from the burning when I realized what was happening I saw the words "KOYO" in darker red colors than the rest of my hand. If it's really hot to the touch, don't worry too much, that's pretty normal for the aluminum radiators.
Nismo_Freak
Car: 89 Nissan 240SX
KOYOwned!
GTS4-R
Car: my feet
well obviously u wont be ablpe to touch a rad for more than a sec anyways....haha
could be thermostat or your water pump
also u sure ur fans are comin on?
kylaris
well.. I replaced the water pump and the thermostats.And the fan is on. I have it wired to a switch.
GTS4-R
Car: my feet
so hows it running now?
kylaris
actually the pump and thermostats been replaced about 2 days a go. It was over heating according to the stock gauge even after change.
I put digital thermostat on the radiator frame so I can see how hot it gets(couldn't buy the water temp meter yet). And it was around 80-85C. So I believe the water should be around 95C at most.
GTS4-R
Car: my feet
then the gauge/sensor must be off.....mine operates at 80C up to 100C when its hot and i tool on it
180fan
Car: 89 fastback
just out of curiosity, did you bleed the cooling system properly?
busky2k
You have to fill the cooling system with the lil bolt on the cast inlet coolant housing undone. Once it starts streaming from the hole, u plug it up and keep on filling. Otherwise you create pockets of air in the head etc. No good!
kylaris
I just filled it up and ran the car for short period of time then refilled it.
Doesn't this work as well?
Rookie_ca18
Car: women, sleep, cars
Have some1 watch your gauge and you watch the fan and see if the fan is coming on as the temp starts tor rise. Maybe your fan isnt working right. I have a permacool as well and it was doing that for 2 days then it started working right all of sudden...go figure?
JJ240
Car: 95 white 240
Are you using an S14 temp sensor? Ive heard that the S14 gauge will read wrong when you have an S13 sensor feeding it.
kylaris
nope, I'm not running s14 sensor.
That seems to be causing it, since the digital thermostat, I hooked up to the upper radiator hose seems to be around 95C or below, yet the stock gauge says I'm overheating.Around 90C and up the stock gauge is @ H and higher. Which makes me worry a bit.
