SR Running Rich? Check this out...
200RX
Car: 1989 Nissan 240SX SR Black top
Hey Everyone
I'm on http://www.240sxforums.com and I just posted a thread that I think would deff help out some of you.
So your SR is running rich, what could it be? Here are some checks and troubleshoots that I have done, other people have done, and I've googled for. So I hope this helps!
http://www.240sxforums.com/for....html
duffman1278
Car: 89 240sx Hatch, the wildcats!
Good info man! I needed this.
0range_Kouki24O
Car: s13 coupe and s14 sr20det w/2.3 stroker
good stuff right here
reds14zenki
Awsome info!! thanks 200RX
shally2186
Car: S14.5
heyo, very good advice..instead of replacing everything you preferred, i was wondering if you could try to help me out?
i have a S13 SR20DET swap in a 90 240sx coupe
it runs very rich and can barely hold an idle unless its started when the engine sat and is cold. i replaced the plugs and MAF. it will barely be idle'n and about ready to stall so i unplug the MAF and its idles fine..any suggestion? ive looked all over for vac & Boost leak and can't find any..
ALSO i was told that the engine has HKS cams but that's it..
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Nice compilation.
