240-slide-ride »
https://forums.nicoclub.com/240-slide-ride-u79396.html
Thu Apr 02, 2009 10:18 am
ive got a 89 s13 with a s15 sr swap, and it is running LEAN. the timing is correct crank pulley, cams etc, ive counted the teeth going from cam dimples to head and it's all dead on balls. the car runs good and starts ok, goes into boost very strong but falls on its face at a certain point. after that happened i pulled the plugs and they were white, even the electrodes were white. i havent got a vacuum gauge or a timing light on it yet but im working on that. also the CAS is cranked almost all to one way to get it to run/start. what else could be causing my car to run so lean? i havent been driving it since finding it lean. another thing i have noticed is it came with a electronin boost controller that appers to be not hooked up, and it looks like the lines under the hood were removed but not hooked up as well, could this have anything to do with this? btw there new spark plugs gapped at 27 i had them at 32 before, seems to have done nothing
