Try replacing the coolant temp sensor. One from a KADET will work.bassboost wrote:hmm...any chance a sensor went bad..cause it was running fine then all a sudden everything went downhill
Unbolt the fuel rail from the manifold. Turn the key to run and look for fuel coming around the injectors.bassboost wrote:how do i check for leaky injectors..i've tried 2 diff fpr's...
oh haha, I guess I would have saw that if I read the whole thread before posting. Boost leaks suck and can make your car gay.bassboost wrote:Nope..I think I found the problem..being a hole in the intercooler piping. I'm no longer getting 10.0 AFR readings, everything seems to be looking good. I need to turn my boost down today to get my AFR's in a better higher rpm reading. Right now its looking high 12 AFR's....
glad to here its running well again bro. enjoybassboost wrote:Yeah, no biggie. So I turned my boost down to about 14psi..everything is running GREAT now Thanks for all the help guys/gals
