:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Tue Feb 22, 2005 5:25 am
FMU has nothing to with it in this situation...
The Nissan engine managment systems use a MAF to read the airflow coming into the engine...as the ECU reads more airflow, it tells the injectors to dump more fuel.
This is only limited by the amount the air the MAF can accurately measure (max of 5.11 volts, stock S13/S14 SR MAF can only read ~250rwhp worth of air) and the max of the stock injectors, which is also around ~250rwhp, maybe a little less.
Very simple and effective.
Now, with respoect to FMUs...the stock fuel pressuire regulator is a 1:1 ratio FMU of sorts...but this is only to keep the fuel flow constant. A 1:1 FPR keeps the pressure differential across the tip of the injector constant, so the flow is ALWAYS measured at 3bar (43.5psi) fuel pressure.
Same reason why the fuel pressure is lowered under vacuum (idle)...~20in vacuum is about -9psi, so the fuel pressure is lowered the same amount to keep the flow constant.
- Brian
(BTW, 15psi is BAD on a stock turbo for an S13 SR...the T25 is blowing a TON of hot air in that efficiency range....most keep the max PSI of a T25 on an SR to 14psi or less)
