Will the KA Reverse Lamp Switch work on my SR transmission?
http://www.courtesyparts.com/3....html
I have traced my reverse light problem down to the reverse sensor/switch.I have a manual switch to connect the two wires on the switch, and everything works correctly. So I want to replace the switch out.I tested the reverse sensor for continuity between the two wires when the car is in reverse and nothing. Tried with it off and also in accessory. The weird thing is that this is a replacement sensor that I purchased from someone online.The one that came with the motor was beat up and didn't have the plug. Neither of them measure continuity when pushed in. Hopefully I just have 2 bad switches.
I've done a lot of searching on this topic and have fought with this problem for 3 weeks now. I also had to repair the grounds on the reverse bulb sockets. I've been through the whole system, and have finally narrowed it down.
Also had to tear apart the passenger side turn light housing and reseal them to fix a leak (twice), and now I have a burnt headlight.I'm just trying to get my car inspected, the sticker on the car is from 2002!!!
Thanks for any help in advance.
