zachw »
https://forums.nicoclub.com/zachw-u148649.html
Tue May 25, 2010 1:56 am
oookay, so im just gonna come out and say my 240 started giving me problems last thursday. i decided to just park it at my house and do a little research. earlier that day where i noticed the problem i pulled onto a main road around where i live following a friend to work and tried to catch up to him and my car started to jump and skip..consistenly. almost as if i lost all compression in a single piston. considering my coolant kept getting lower and lower even though it wasnt leaking onto the ground, i figured it was leaking into the oil pan. i pulled it into my garage after put-put-ing it home and drained the oil as well as the coolant (oil didnt really look like it had any coolant in it, which stumped me) took the intake manifold off, the exhaust manifold off, and just a couple of hours ago took the head off. i figured it would be a cracked/blown head gasket because, honestly because that problem did sound a ton like a head gasket issue. i already have a cometic 1.01mm that came in the mail not too long ago. i didnt see any problems whatsoever with the stock head gasket. is it possible that even though it doesnt "look" damaged it actually is? any other ideas to why it was skipping and jumping so much? it hasnt ever done this to me before and its my daily driver so i have to get it back on the road asap. btw, now that he head is off, what all do i need to have done to it before i put the new gasket on; machine work-wise i mean. i've heard its a good idea to get it shaved, but i dont want to do that so much that the valves hit the piston heads..that would make for a fun time. i hope someone out there has an idea :/ thanks in advance.
-Zach-
