DriftBandit »
https://forums.nicoclub.com/driftbandit-u10686.html
Mon Sep 20, 2004 10:21 am
I doubt autozone will have these parts since this motor never came to America, You can go to some of this sites sponsors pages(e.g Phase2motortrend, Heavy Throttle, ect.) I know some of them have OEM sr20det parts.
As far as the heater hoses you will have to rig something up to connect them.
For the throttle cable you will have to use the KA cable, there are different lenghts for S13 and S14 cables so you have to figuer out which one to use, I am not sure.
For your exhaust if you want it quiet you can try putting in a Hi-flow cat or resignator, The test pipe is a hollow pipe and will not quiet it down, However whatever you put on to quiet it down you will loose some HP.
Hope this helps some. Good luck-Jon
