ca18detpowered »
https://forums.nicoclub.com/ca18detpowered-u48340.html
Thu Jan 04, 2007 3:57 pm
Ok, theres a few different sr20 with different things about them
s13 redtop, 205 hp, t25 turbo, usual stuff. s13 blacktop, i think its pretty much the same thing....corect me if im wrongs14 blacktop. Has valve control similar to vtec, t28 ball bearing turbo, 220 hp
s15 blacktop- 250 hp, 6 speed transmission, also has t28 ball bearing turbo, best of the sr20's
when they say long block, it means no transmission, wiring, or accessories.
you want a complete swap package if you wanna do it. It basically bolts in the same as the stock motor does, everything is same, cept for exhaust, unless you have a stock downpipe, then it bolts to the stock 240sx cat, but who wants to do that (=
also you need to do wiring, very easy, match the colors. Its all covered by the heavythrottle guide. Heavythrottle.net for more info
