not really missing anything, at the 300hp level there's not really much of a monetary difference between the two.you'll need a turbokit for the KA wich costs as much as an SR ,and an upgraded turbo.so look for a little more wrench time on the KA at the benefit of a little more torque.unless you're paying for labor at wich point i would guess you'll pay more for a 300HP KA.burnin240sx wrote:i think i've choosen to go with a ka due to the iron block and the more displacement. unless i'm missing something here?
burnin240sx wrote:i'm sory i don't understand what u mean by square ratio? i do plan on changing the compression to 8.5 when i do the internals. cause it has hi compression and that's good for na but not turbo. is this what u mean? or are you taking about storke length?
burnin240sx wrote:i think i've choosen to go with a ka due to the iron block...
Phax wrote:I went with the SR, because I truly believe that when it comes to flowing a lot of air, and high boost levels, the SR is a better, more turbo friendly engine. If you're content to stop at ~300hp, you can do that all day with a KA.
Nathan wrote:...My big problem is the SR's aluminum block, seems like it'd be way to easy to strip the threads in various mounting holes and things. I cant stand aluminum because I have a tendency to bang it up![]()
J-Spec Tuner wrote:The fact that the block is aluminum really has nothing to do with how much HP the block can take. I have NEVER seen a SR needing a block guard, ive seen stock blocks take 750-800 horsepower easy. That is the worst argument on the planet.
Weight:-SR20DET is ~490 with all the turbo stuff on it-SOHC KA is ~490 with no turbo stuff on it, a KA24DE-T probably weighs 550-600lbs
Stock Internals:-SR guts have been brought to 550hp-KA guts have been brought to 300-310hp (could be higher, but is yet to be explored)-neither power figures apply to a regular person with a regular budget (tuning to reach those power levels is really expensive), but the SR stock internals are stronger. Most regular people only get 240-260 hp out of the stock internals on the KA, and 300-350hp on the stock internals in the SR.
Torque:KA has the advantage, but that doesnt mean the SR has a shortage of it
Price:If you argue which is cheaper you are a fool.
Aftermarket:SR has the advantage
HP per PSI:It really depends. A T88 at 7psi on the SR will make a **** load more horsepower than a 7 psi on base turbo kit for the KA. Even with the same turbos, it depends on other performance upgrades and the extent of tuning.
