180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed Feb 23, 2005 1:38 pm
Does it even turn? Does the starter go? Did you guys check all the plugs, like for the injectors or for the coil packs? When you put the motor to TDC, did you make sure the crank was lined up to the second mark from the left (if you're looking at it straight on), with the intake cam at about 11 o'clock, the exhaust cam at about 12 o'clock, and the cas line up to the farthest most punchmark before the gear section of the cas (two marks, and a cut out line on the cas)? If you did all that, it should at least fire up enough for you to get a timing light out and set the timing perfect.
