Gutling »
https://forums.nicoclub.com/gutling-u27213.html
Sat Aug 06, 2005 12:32 pm
Okay, here is the setup GT25R, 550cc, z32, walboro, enthalpy ecu (z32, gt25r, 550, speed cut), mbc 12psi, fmic, hks ssqv
Ever since installing the turbo and the injectors (have since installed ecu to try to fix it, didnt work) it has been doing this, it will idle and drive fine, until either half throttle 5-6000rpms, or 1/4 throttle 6000rpms, or full throttle 4000rpms, the more throttle the sooner it does it. What it does is like a cut, it just stops going. no backfiring, stuttering, nothing, just quits. until u release the throttle for a few seconds, then it will go again. any gear, any boost, just the more u give it gas the sooner it cuts it. mafs is good, wiring is good, ecu is good. runs a little rich now but not too bad. please any suggestions?
