SR problem - rich idle, lean boost
anyotherone
Car: '93 S13 coupe VH45
I've been working on an SR problem for some time now, and I must confess I'm completely stumped. Any help would be appreciated.
Car: S13 redtop into S14 chassis, SAFC, Z32 mafs, fmic, stock everything else
Problem: car idles/runs very rich, then goes lean when I try to get into boost.
Things I've checked:
MAFS/wiring - good, replaced old maf w/z32 to be sure, revs over 3k rpms
Injectors - no leaking as far as i know, pulsing like crazy though
Ignition - getting spark, timing set correctly using timing mode
CAS - Switched from old brken one, seems to test out ok per FSM
ECU - swapped with two other ecus, one functions exactly the same, one doesn't start and throws code 14 (VSS) and 21 (ignition switch) ???
Wiring harness - wiring performed by swapwiring.com, everything I've tested so far seems good
Vacuum leaks - tested, no leaks found, replaced wastegate on turbo earlier because it was leaking bad
Spark plugs - raw fuel, cylinders getting flooded
It seems like the injectors are being told to fire to often, what causes this?
Emperor_Tha
this is my setting
safc setting 6 in 2 out. idle setting low point 750 rpm +16, high 0. idle should be 14.7-16.0. high throttle point , 3000rpm-5000 +5-+7. 5500rpm- 7500 0- +1
a/f should be 12.7 then drop to 11.8, maybe 11.6 sometimes.
if you keep running lean, check your fuel pump. my walboro when bad after driving for 1500 miles. its would somehow crap under full throttle.
codyace
Car: S14 w/redtop
Did you try removing the SAFC, swapping the Z32 maf for a stocker, and seeing how it ran?
schanne
Car: 93 Hatch-Sr20
You need to get rid of the Z32 Maf. There's no need for it unless your pushing some serious HP. I had one myself and it only cost me more problems and $$$. Put the stock Sr. or get a Ka Maf.
Oh yea, I almost forgot. Get rid of the SAFC too. Notice mine are for sale too.
codyace
Car: S14 w/redtop
schanne wrote:You need to get rid of the Z32 Maf. There's no need for it unless your pushing some serious HP. I had one myself and it only cost me more problems and $$$. Put the stock Sr. or get a Ka Maf.
The main issue is having the ECU setup and calibrated for the Z32 maf.
Serious hp? Um, try any car making more than 250 whp should use a z32 maf.
schanne wrote:Oh yea, I almost forgot. Get rid of the SAFC too. Notice mine are for sale too.
Yes! Another SAFC owner see's the light
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Quote »Yes! Another SAFC owner see's the light [/quote] they are the equivalent of playing with fire.
To OP, something is causing the injectors to fire funny. Do what Codyace said and then come back if the problem is still there.
