codyace »
https://forums.nicoclub.com/codyace-u28194.html
Mon Feb 22, 2010 8:53 pm
Learn how to shift, that's the obvious answer
THrowing rockers can result in 2 issues: None, or bent s***. You also are now invited into the 'shim and guide' easter egg hunt' for your engine. Make sure you find both before re assembly.
9/10 it's just a toss off that you can re assemble without issue.
FWIW:
ROcker Arm Stoppers are great, but bend valves. No stroppers can result in the same issue. Your choice.
