SR problem..Choking under light throttle. Mafs???
Eternal_240sx
Well i have a problem with my redtop. Under light acceleration my engine will start choking when i hit 2500rpms and up in all gears, it would choke then stop for a couple of secs then choke agian and agian etc. If i go to medium or hard acceleration there will be not problem at all. I first thought my mafs could have been messed up so i used a sohc mafs. For anyone using sohc mafs on there car the pins go like this correct?
SR ----------- KAB -----------> AC -----------> BD -----------> C
This is what i found on NICO, but it seems that it may not be the MAFS if the wiring is correct. What else could be the problem?? Please help.
My mods are:Intake, downpipe, test pipe, and exhaust. Thats all...
Thanks
SpeedRacer1
Car: 1990 240SX, G35
Check your ECU for codes.
180fan
Car: 89 fastback
Match the colors. They're the same for the SR MAFS and the SOHC MAFS. If you're able to rev past 3k, chances are it's not a bad mafs. Give it a cleaning though with some carb cleaner and don't shoot directly at it. It's pretty fragile stuff. It's only at low acceleration...did you try running a fuel system cleaner yet? If you're mashing it, mashing it could just mask the roughness but the problem could still be there. Also do a plug read. That should give at least a better idea of what's going on inside the combustion chambers.
