PAsrfreak wrote:Greetings-I am going to be doing a swap in a few weeks, so i'm starting to compile everything I need for the swap. I had a few questions about the best items to replace before installing the engine, while I have it on a stand. Here's what i've got so far:
head gasket, water pump, tstat, fr. and rear main seals, exhaust mani gasket, plugs
Check the timing chain out for excessive movement. Also look into the complete oiling system. Make sure everything like the pick-up is clean, and the oil pump gear is not out of spec.
As stated, get a gasket set to simplify life.
Make sure you follow proper torque specs, aluminum is not forgiving.
PAsrfreak wrote:Also, I plan on upgrading the turbo eventually, and I was wondering if you guys would recommend doing it while the engine is out. I've never removed a turbo assembly before, but i can imagine the bolts can be a nightmare to take out in some situations. Drilling and tapping is not my favorite thing to do, I'm sure you all agree. It's basically a money consideration, but if the overwhelming recommendation is to do it with the engine on a stand if possible, I'll spend the money now instead of later. If there's anything else you'd advise doing based on the convenience of having the motor on a stand, please chime in, thanks fellas-
It's a pain to do in the car, but honestly it's easier to get the engine in and running with a stock setup. This also allows your T25 to eat a bunch of start-up metal when you run the engine in. Once you get it running fine with the T25 you will know you have a good basis to work off of. Slapping mods on a motor and throwing it in not knowing if the basics work is a big nightmare to fix.
PAsrfreak wrote:btw, in case you didnt notice, i'm new to the forum and fyi, i'm a performance parts dealer (small time,starting out) and am very willing to be as competitive as i can price-wise, especially for fellow motorheads
Just to let you know, we have an advertiser policy on NICO. Unless you are an advertiser there is no pushing of business on the site. I'm particularly nazi about this because I have been in the business for about 3 years now and understand how it works.
If you'd like to get setup with some advertising on the board just email
[email protected] and he'll get you setup. It would be a good idea to get everything in order before you start branching out though.
Welcome to NICO
