maxima278 »
https://forums.nicoclub.com/maxima278-u20438.html
Wed Jul 19, 2006 2:52 pm
I'm putting a blacktop s13 sr in an S14, and it seems that none of the power steering stuff lines up. The hose from the reservoir appears to be too skinny to go on the sr pump. Do I need a different pump or is there a different kind of hose that I need?
Also the metal connector from the steering rack (the one with the large bolt that goes through it) is too small. Looks like it was fitted with an adaptor and if I take it off it will bolt on, but then the hose will be at an unnatural angle. How do I make this all work?
