gt3071r240 »
https://forums.nicoclub.com/gt3071r240-u19723.html
Tue Sep 14, 2004 4:47 pm
i saw that you checked to see if there was vacuum in the line going to the booster, however did you make sure that the booster is ooperating properly? If you dont know how ot do this all you have to do is start the car let it run for a few sec (10 is enough) shut the car off. After a minute of the car being off pull that black vacuum line out of the booster, and it should make audible noise. the noise is the diiference in pressure between the inside of the booster and the atmosphere. if there is no noise your break booster is bad.
