Please call me only im on so may forums it gets confusing 704-746-4468 Alex
everything listed can be shipped if you pay shipping unless we work a deal other wise
Toyota CT26 (mk3 supra) turbo Rebuilt $250
All S13 SR20DET parts
Redtop Short Block $450
Bear head $200
Cam angle sensor $120
Idle air control $70
Valve cover (custom purple) $150
Stock intake and exhaust cams $100
Stock Cam gears $10
Valve $40
Valve Spring $50
Intake Mainfold $100
Coolent Tube $10
Front timing cover $70
Cam shaft caps $50
Pistons and rings $80
Crank shaft $120
T25/T28 compressor outlet $40
Rear cover $15
Flywheel bolt $20
Lower Oil pan (perfect still has sticker) $40
Upper oil Pan $90
Alt. $60
A/c Pump with bracket $110
S13 Seats black with no rips one peice seats $100
#62 ecu $100
Full wireing harness $280
trans $150
4 teardrop wheels with tires $100
S13 Hood $50
S13 hatch taillights $90
turn signals $10
Lower grills $10
Radiator $20
Downpipe $20
2 sohc maf $20 a peice
1 dohc maf $50
T25 needs rebuilt $40
Stock exhaust mainfold $50
s13 hatch sunroof glass $20
Modified by typicalsr240 at 11:07 PM 2/1/2009
