Kenrik »
https://forums.nicoclub.com/kenrik-u28233.html
Mon Aug 28, 2006 11:27 am
Ok so I hooked up my boost gauge and went for a little drive... driving up and down my street I was hitting 10PSI and I was like WTF? I have not messed with the boost level at all yet, I reved a bit more and I saw the gauge tap 15psi... ohh ****, I have a Walbro but the car is not tuned at all.
Nothing happend, I did not blow anything up and the car still runs great but I know there's something ****ed up with the wastegate... could it be the VAC line I have hooked upto the actuator is to small?? (just that normal size small vac line that the KAs usually use) Or is it that my boost gauge is reading more boost then I'm really making?? It's hooked in near the turbo that would make a difference right?? should it be hooked up closer to the TB?
Blah... a busted brake booster and a boost spike in the same day.. I just want to drive
