sr or turbo sohc
big monkey racing
Car: 1990 240sx
I was thinking of going Sr but I did a little research and the ka can make more power more reliable. I didnt want to go to crazy with anything and also I think it will be less stress since my motor only has maybe 15k on a stock rebuild. I'm not looking to make a ten second car just something fun and reliable all input appreciated
S133P3R
Car: 1989 S13 240sx
big monkey racing wrote:I was thinking of going Sr but I did a little research and the ka can make more power more reliable. I didnt want to go to crazy with anything and also I think it will be less stress since my motor only has maybe 15k on a stock rebuild. I'm not looking to make a ten second car just something fun and reliable all input appreciated
if you trust your rebuild, a fun KA-T might be more easily attainable. figure, you buy a "60k/km SR" and youre just hoping it wasnt driven by someone like me =)
IRON>EVERYTHING.
big monkey racing
Car: 1990 240sx
I did the work myself and the motor has given me no problems
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
I'm not trying to start the never ending battle between sr and ka, but the sr is far more reliable than the ka. (yes I started with the ka just like everyone else) however if you have a fresh.rebuild... There is nothing wrong with going kat which had become much more respectable than it used to be. Just like s133p said, most sr swaps have been driven hard and put away wet by the time you get your hands on it. Take the money you would spend on a swap and just buy all the turbo stuff you need. Probably cheaper too.
S133P3R
Car: 1989 S13 240sx
always thinking about the $$$$ aspect of it, and adding a few parts to your set-up is far cheaper than starting new....
i think.
big monkey racing
Car: 1990 240sx
How much would I be looking at and I don't want to be cheap bit I'm not made of money would I be better off buying a kit or part by part
compactfean
daily
My personal experience, id piece together my setup. Kits are expensive and usually there is always something I don't like about the kit. Not to mention, you get to choose what you want for every aspect of the build. Turbo, manifold, turbo lines, bov, wastegate, intercooler and piping, injectors, ecu, maf, fuel pump. Do your homework on what turbo you want, how much boost you want to run and how much horsepower you're looking for and research the parts on everything I listed and you'll be happier choosing everything yourself. Not to mention, yes, it should be cheaper.
blkvrtswp
Car: 93 240SX Convertible
SR20DET FP 20G Turbo
First question - where are you going to find a SOHC KA turbo manifold?
EDIT: After a quick search, I should say "Where are you going to find a GOOD SOHC KA turbo manifold that isn't $700?"
compactfean
daily
blkvrtswp
Ah, that looks a lot nicer that the log crap I was seeing. Nice.
big monkey racing
Car: 1990 240sx
I'm not looking for mad power just enough to make it fun and still be reliable.
