k6kicker »
https://forums.nicoclub.com/k6kicker-u10135.html
Thu Dec 23, 2004 8:48 am
ok here is a helpful post:
If you want the best low end/mid rnage punch (power you feel driving everyday, not just going flat out on it) go for a hopped up ka (hot cams and a header, turbo...whatever route you wanted to go on) also it would be the cheapest to maintain sense all your parts are going to be well the ones that should be there (but i hope you build a monster out of her and get some forged internals)
If you want a wild top end pull (ala wrx) go for the sr or the mighty mouse ca.....the ca can cross refernce a bit more then the sr (as far as my experences go) but either way, if something goes foul, you are paying (unless you can do a lot fo the work yourself, which i will assume is false)
others to keep in mind (as in non-nissan):
a 302 (aka 5.0) more then likely isn't far from the wieght of a ka(t) and has a HUUUUUUUUUGE aftermarket...there would be a lot of custom fabbing to get it to work, but it would be pretty cool....same goes for an LT/LS series motor, just a little heavier and more expensive (that is for the ls)
and for the record, you basically want a turbo for each bank of cynlenders you have...which is why the wrx has problems with one, as the manifold has to push the exhuast gasses all the way to the other side...and putting 2 per bank is cutting your effecency by pretty much doubling your losses to friction and heat...ect) Inline=best with one V=best with 2
