SketchyRollin564 »
https://forums.nicoclub.com/sketchyrollin564-u60600.html
Tue Nov 22, 2011 11:25 pm
Which RB are you referring to? The RB26 or RB25 will be superior. The RB20 is also nice motor, but the SR20 in my opinion as far as power and price is just as nice. I love mine. My only complaint is the lack of low end torque that you have in a KA.
They are both good motors. I have an SR in my s13 and I have a friend with an RB20 in his s14. Ill try to compare them both for you from my experience.
The SR is a very well built and well designed motor that can handle a decent amount of abuse. It can handle about 350whp on stock internals so so long as you have a proper tune and take care of it. The RB is also a pretty decent motor considering how old it is, however im not sure how much power they can handle on stock internals and i dont know too much in general about that engine. The SR is newer and can be had for cheaper. So thats a plus.
We both beat the crap out of our cars and they both hold up well as long as we take care of them. The RB does sound nicer than an SR (on average), but the SR still sounds beastly so long as you choose your exhaust system correctly. Ive heard a few SR's that sound like garbage, and ive heard a few (like mine) which sound pretty damn nice for a 4 cylinder.
Power wise, stock for stock, its not too different. The RB20 may have a tiny bit more power and a slightly bigger turbo (T3), but its also a good 200lbs or so heavier. Will probably be just as fast with either motor.
Just to give you an idea. my friends RB has pretty much the same engine mods as me. Stock T3 turbo, upgraded fuel pump, front mount, intake, and exhaust. My SR has the stock t25, upgraded fuel pump, front mount, intake, and full exhaust with stock manifold. With me on 8psi and him on 11psi, we were even any time we would race.
Im now on 14psi. I couldnt tell you how much i pull ahead because we havn't raced since, but i can tell you the car pulls very hard and runs strong, even without a proper tune. It pulls hard through all 5 gears, and first gear is pretty much useless unless you have decent tires in the back (which i dont). Ever since ive raised my boost, i havnt been able to go full throttle in 1st gear without spinning once i hit my power band. The car is a blast to drive
A basic bolt on SR without a tune wont really start to make power untill after 4k. Before that, its kinda sluggish, at least compared to a stock KA. The RB20 is the same way, doesnt really make any power untill after 4k. The RB25 i would imagine makes a lot more bottom end power, and spool turbos a bit quicker due to its displacement.
Cost wise, the SR would run a lot cheaper, and will for sure be easier to swap. Parts are easyer to find, and replacing things will be cheaper. Unless you have a lot of money to pay a shop to do the labor, if your going to do this yourself and dont have much experience, i would go with the SR. Anyone with an RB will tell you that parts are EXPENSIVE. Not to mention, it doesnt just drop right in like an SR would
good luck to you and whatever you decide
hope my post helped
