hstylez »
https://forums.nicoclub.com/hstylez-u38933.html
Wed Mar 28, 2007 5:35 pm
As the title says, im looking for the size of the copper washers for the banjo oil feed line that threads into the block. Ive been searching for this for awhile and have only had luck on the coolant washer size. I took them to autozone and Napa and neither had the right size. I was able to find the size for the coolant lines but not the oil line. The oil feed is the smaller of them. Only reason I ask on here and not go out and measure is that I'm 200 miles away at school and would like to order them before I get home. If anyone knows and can include a inner diameter and an outer diameter I would be very gratefull......
