SR Not Boosting after cam replacement...
mikesr86
Car: AE86 Sr20det swap
ok...so i recently did a hg on my sr redtop and everything was going well until I made the biggest mistake ever...I left the dam ratchet on the crank and it got stuck while I was trying to crank the engine and it actually started...the car sounded like crap though...it would not rev...i removed my cover and my exhaust cam broke...so i replaced the cam and the car started right up...the idle is perfect and the engine sounds ok...when i try to rev the engine it sounds weird...it revs strong but i dont hear the turbo spool up...i do get a little air out of the blow off valve but thats it...the turbo is fine and I made sure everything is connected properly...I guess my question is did I probably damage my valves since my car started with only one cam working?
Sugar
Car: S13 w/ Sr
These questions irritate me. Yes, you probably did. But no one here can tell you, check compression and know for sure.
Turbo won't generally spool without a load, so don't expect to hear to much if you are just there rev'ing it by hand.
