Im A NooBie wrote:Yeah its still using the stock radiator the guy who installed it told me that the stock worked better than the aluminum on his s14 thats why he didnt put a new one in the S13.
uhhh... no.
anyways, start putting on a big turbo, big injectors, big cams, valve S/R, nice tune, lots of boost, etc, etc. If you get bored then you can get forged internals and even bigger turbo haha. Oh and more boost.
Anyways, on a more realistic note... SRs are not very hard engine to work on. Few of things that I hate doing.
1. Replacing the oil pump with the engine still in the car2. Taking the trans off and putting it back in with the engine still in the car3. Valve springs w.o the right tool. This would be difficult on all engines without a proper valve spring compressor or a valve keepers tool4. Hunting for boost/vac leaks. Ugh.5. How easy it is to strip the threads on the block (alum). Especially the oil pan bolts. Arg. Next time my engine comes out all of those farckers are getting heliecoils.6. Make sure you get torque wrenches to prevent your threads being stripped. I recommend one that measures in in*lb and one in ft*lb.
Besides those things... they are pretty easy to work on.
