SR No Fuel???
Trax07
Car: 1990 SRed 240SX
Ok it was only cranking. Check to see if had spark and yes. Check to see if fuel and it gets to the rail and I guess is clogged or injectors are ****ed. Put gas in the throttle body and it turns on but turn it off and try to start again and nothing....
S13 Redtop SR. Also when we pull the fuel line it shoots fuel everywhere as its being clogged or just building up pressure...
Anybody?
Modified by Trax07 at 12:34 PM 11/12/2008
Trax07
come on somebody must know....
nzmoman
Car: 240sx 2 of em' and always lookin for more
are your lines correct. I don't know what you mean by it gets to the rail, but if the pump is flowing and you don't have a clogged filter then you need to check your lines. If you want to know if it is really getting into the rail pull the line off the FPR...if it squirts gas every where then you need to switch your lines.
Trax07
its done that either way i have put the lines...
corrected it doesnt shoot out fuel from the fpr....
so...?
Modified by Trax07 at 3:13 PM 11/12/2008
SR240SEX
Car: 91 240sx
First off, is the fuel pump turning on? Make sure that the lines aren't back wards,. Check the following; fuel pump fuse, relay, wiring for the lower harness (connections good)?
Trax07
Thanks for helping...
ok I have checked
FuseYes the pump is working Changed the filter because it was old and kinda cloggedconnections are good but the starter makes a funny noise i will try to get a video up...lines are not backwards
Trax07
any other "to do's" it's real helpful being as this is my first sr .... just lmk what you would do and i will do it. How can i tell if my FPR is FUBAR!?
SR240SEX
Car: 91 240sx
SR starters are prone to making odd noises. As long as it's not a grinding noise, I wouldn't worry about that too much.
Check to ensure that you are getting power (12v) to the injectors, there should be 1 common color wire that goes to each injector and it should have power to all 4.
Did the car run normally before the swap? It may be that fuel is getting to the fuel rail, but not enough pressure for the injectors to spray properly. When you're removing the fuel lines after trying them in different configurations, is there a lot of pressure in the lines? If not then I suspect the fuel pump is faulty.
If there's a lot of pressure in the lines, you will need to test the injectors. First and foremost unplug the harness for the coilpacks (rear of head), now unbolt the injector rail and leave everything (wires/ hoses) connected and have someone crank the engine. If no fuel sprays out, and the injectors have power and the fuel pump is good, then it can only be the injectors.
It is not uncommon for all the injectors to go out at once, too..
Trax07
im thinking its the fpr. shouldnt it return the fuel its not using? i have the fuel line off of the fpr and nothing comes out.
also the starter makes a loud kind of a chirp sound...
i leave the car alone for about a hour then go and start it and it will start and idle for about 5 sec. then dies...?
Trax07
ok i just shot some air through the rail and it finally threw some fuel out the fpr. is it that im not getting the correct fuel pressure?
SR240SEX
Car: 91 240sx
It's not the fpr, so quit spraying compressed air in the fuel system. I told you how and what to do.
