ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Mon Mar 06, 2006 7:53 am
Symptom: Noticeable rattling at part throttle at about 2500~3000 RPM. Very loud and fast rattle at full throttle and at around 5500 RPM. Oil pressure at idle (900 RPM) when warmed up is around 25 PSI and at 3200 RPM 75 PSI. The noise seems to be coming from the top of the engine. First I thought it was the timing chain, so I took off the valve cover and started up the car for few seconds. I noticed that all the oil is squirting on to the cams and heard a loud rattle where the exahust cams were when reved to around 3000 RPM.
Engine: Stock rebuild 2000 miles ago. This includes rings and all the bearings. Clearance was checked on all the bearings. Just replaced the head with a used one. Also used cams, rocker arms, lifters, shims (all the moving parts on the head from a different head)
I cannot seem to figure out why this noise is keep happening... Any inputs will be appreciated. Thanks!
