SR MT Speed Sensor Bad?!?
ShaggyS13
Car: 1989 240sx Coupe SR20DET
Ok I was driving on the freeway at about 75 when my speed sensor decided to goof around and stop working, it moved from 75 ta 0 several times and then just stopped working over all. i check the wiring connections and found duck tape was holding some of the wires together, so i fixed that. Still the speed sensor refuses to work so i am guessing that my Speed Sensor is bad. I was wondering were am i suppose to order this part from sense its the SR trans.
snake240
Car: 92 hatch SR20DET
get one from a ka. the orig sr sensor is gonna read in kmh. you need mph.
heavythrottle
Car: 1993 240SX Convertible
JDM and USDM S13 MT speed sensors are exactly the same. There is no difference between MPH and KPH except the markings on the speedometer face. ________________________________Jeff HSR FAQ @srownersclub.com/index.asp
CMG
Car: 1989 240sx Hatch w/ Redtop
heavythrottle wrote:JDM and USDM S13 MT speed sensors are exactly the same. There is no difference between MPH and KPH except the markings on the speedometer face. ________________________________Jeff HSR FAQ @srownersclub.com/index.asp
BS
